After a year of plasma cutting with SC, I’ve recently begun wood routing with it, since most of my CNC routing is contours, pockets, and v-carves. A recent project involved cutting several small odd shaped pockets in a piece of red oak. In order to chamfer the top of the pocket edge, I drew an outside offset of 1mm around all my pocket shapes, then I used a vcarve operation with a 90deg v bit at a dept of 1.5mm (my v bit has a 1mm flat tip). Question- is this the best method to make chamfer cuts ?
If it is, for perhaps a simpler method, consider a future new feature of “Create chamfer” on pocket and contour operations much like the companion “Create pocket” feature is on the v-carve operation. This “Create chamfer” check box would need a companion input field to specify the offset from the shape which is the chamfer top edge.
