Hi! Is there a rule or advice as to which DXF version to use when importing to Sheetcam? I am currently in a process of setting up my CNC and I will most likely purchase Sheetcam, as my friend uses it and it seems to be the best CAM for 2,5D I will mainly use (I make guitars).
Would I experience problems if I used “newer” DXF versions, such as dxf 2010 or higher?
Thanks!
