Just beginning to use sheetcam and having a bit of difficulty.
This is for a large fabric plotter/cutter with solenoid driving a 28mm rotary blade, plotting pen and future hot knife. Have been using the Mill/router tool for the cutter and tried the plasma tool for the plotting pen.
No problem with the gcode work flow process so far…but
My problem is the I’m using the EdingCNC controller which doesn’t recognize G91.1 command. Once it gets to the line with the G91.1 it throws an error (L4: Unknown g code used). I’m using the Mach3 tangential with 3 heads post processor which generates a G91.1 code within the file.
