G81 Drill Routine?
I have very limited knowledge in SheetCam, I can usually mill, drill and tap
and finish a part. I’m using the latest version with Mach4 on a mill.
I would like to speed things up by having the drill bit rapid travel in
the Z axis to just above the surface, and then drill at the feed rate.
Is this possible with SheetCam?
Larry
