I have this DXF image and when I run processor it double cuts. The middle part and all the other parts ???
sharkys final sign version 2.dxf (854 KB)
Zoom in on your drawing. You probably have a double line. This sometimes happens with an auto trace.
Sheetcam got rid of double line… I put everything on layers . Going to pen plot it today and cut it if it works … Pen plotter saves alot of metal…
I just tried the drawing and can’t see any issues with it. Did you accidentally set up two cut operations?
Thanks for all the help … I put everything on separate layers and it cut fine… Thanks Les
