Error when exiting Sheetcam
I am getting a error when I exit Sheetcam sometimes. I am running version 5.1.26 because this computer is not hooked up to the internet.
“We are very sorry but Sheetcam TNG Development has encountered an internal error. It would be very helpful if you could send a debug report so we can try to find out what went wrong.”
The next screen says"The instruction at 0x778fc3cb referenced memory at 0x00292c38. The memory could not be written.
Click on OK to terminate the program."
Any ideas?
I have had a few reports of a crash on close but it is so intermittent that I haven’t been able to track it down.
So should I reinstall it or update to the latest version?
It may be worth a try. Do you have all of the latest Windows updates installed? That has helped for some people.
I have same problem mine does it about 80 percent of the time.im all up to date with everything on Windows and sheetcam.
Running fine here apart from both tng and dev versions stop responding when pc resumes from sleep, all up to date.
I reinstalled Sheetcam and have the same problem.
