That is an arc fitting tolerance issue. G-code only understands lines and circular arcs. To try to keep the output code as clean as possible SheetCam tries to convert the curves in your S into a series of arcs. If your arc fitting tolerance is too high this conversion can be too aggressive and cause distortion.
Go to Options->application options->drawing import and reduce the arc fitting tolerance. Try halving it. You need to reload the drawing for this setting to take effect.
I’m using the dynatorch post processor with “no feed” for a dynatorch
machine. All is fine and SheetCAM is working good. Just thought I’d ask, is
there any way to turn off the warning each time I use the post processor.
The Warning is sheet cam telling me there isn’t any feed rate specified.
I know it’s trivial, but just thought I’d ask.
Thanks for all the help and support.
aj
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2899 / Virus Database: 2641/6138 - Release Date: 02/28/13
aj
aj
aj
aj
aj
aj
aj
aj
aj
Edit the post processor and look for function OnNewOperation(). Remove these three lines:
if (feedRate <= 0) then
post.Warning(“WARNING: Feed rate is zero”)
