Drill a hole in center of pocket
if I select some areas for pocket milling and if I’d like to drill a hole in the center of each pocket (i.e. where the pocket cycle starts) to make it easier for the following tool to work, is there a function or a variable to support me for this ?
If not it would be a nice feature to add :
a ‘Drill a hole in the center’ - cycle ?
Richard
Hmm, there isn’t anything in place to do that at the moment. It can be done with a custom post processor but it is a bit complicated. Have you tried ramp cutting? Ramping at an angle of 15 - 30 degrees makes a huge difference.
No I didn’t try ramping. Just thought it might be possible with a function or a custom post processor as you mentioned.
So I will have to read the pp-documentation.
Perhaps I find a solution.
Richard
It is pretty ugly. Basically you write a post that only outputs code on the plunge (function OnPenDown()). You then use that post to generate the pierces/drill points then you use a separate post to generate the full tool paths.
Can’t you use a part of your spiral pocketing algorithm to extract the startpoint of this moving (spiral pocketing) and use it for a drill operation?
The problem is mainly in how to implement it. Operations are independent of each other so I can’t create a drilling operation that depends on another operation’s cut starts. The other option is to add drilling options to the pocketing dialog but that adds a lot of extra confusing options that few people will need.
Another idea :
If I could set the coordinates of the move-to operation with the mouse I could create a sequence of movements and then add a tool call and G81 at the beginning of the sequence .
Can you add the mouse to the move-to operation ?
Richard
I’ve been meaning to do that for a while. It is in the next dev version.
@ Les : Thanks for your help and implementing this idea ! :smiley:
@ Pete : Thanks for helping me. I’m planning to mill plywood with a thickness of 1/8" or 2/8" and with tools of 3/64" .
Should be no problem though I have no experience with such small tools :wink:
Richard
Pete,
MLCS has obviously great tools but s&h to Germany for example for #202
is as follows :
First-Class Mail International ($17.64)
Priority Mail International ($31.05)
Express Mail International ($38.00)
UPS Worldwide Expedited (SM) ($91.00)
UPS Worldwide Saver (SM) ($95.12)
UPS Worldwide Express (SM) ($98.87)
That’s pretty too much for a hobbiest like me :smiley:
Richard
don’t want to bother you :blush: , but what about an additional option to select / deselect ’ stay in mouse-mode ’ to be able to click more than one position in sequence ?
Richard
Hmm, that wouldn’t be so easy. A move operation only allows one move. For a multiple click to work it would have to create a series of moves. You would then probably have to edit the moves afterwards to check all of the other settings were correct.
My idea was actually to ’ collect ’ some positions to use for drilling in connection with G81/G80 and if I do this I will know that the drilling operation will work with the same parameters at every position. If I need different values i.e. for the depth I will have to add them manually in each line .
And for for use as drilling coordinates the G00 in each line must be removed, too (manually of course)
The same way I could add between each move a subprogram call to mill something like a pattern at this position.
I know those capabilities from the control I use day by day at work (Heidenhain TNC 430).
Anyway I can use it the way it works now :smiley:
Richard
