Digest Number 3072
leson the m09 issue. i did as asked on the pen up with no effect
then i noticed on the pen down it had this
if(toolClass == “MarkerTool”) or tool > 99 then
i pasted that in and it had no effect either
on the rising z axis post;
if i scribe a short straight line it does fine
if i scribe a circle the z axis motor rotates up
i guess i’ve never scribed a circle first
i scribed a square then circle and had no rise on the z axis
the i changed the sequence to scribe circle then square; same file just change in sequence
with the circle first i have z axis rise then steady for the square
at this point i am not actually scribing, using the output to turn my laser cross hairs on/off
On Thu, Dec 11, 2014 at 6:55 AM, <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
SheetCam Group >
1 Message Digest #3072
1a
Re: scriber post > by “Les Newell” les_locost
Message 1a > Re: scriber post >
Wed Dec 10, 2014 4:24 am (PST) . Posted by: “Les Newell” les_locost (> <les.newell@fastmail.co.uk>> ?subject=Re%3A%20scriber%20post)
Do you have the correct Z offset for the scriber in your post?
For the M09 issue I checked and it is a bug in the post. Look for
function OnPenUp() and change this line:
if(tool > 99) then
to:
if(tool > 99 or toolClass == “MarkerTool”) then
On 09/12/2014 21:22, K Ohlgren > kohlgren@gmail.com > (> kohlgren@gmail.com> ) [sheetcam] wrote:
i’ve been using an electric scriber and the '‘plasma MP1000-THC post
processor with engraver’> > ’ post aka mach3 thc with scriber post. it has
been working fine with the exception of i need to manually enter M09
in the gcode to turn it off. i have since bought an air scriber and
modified the air scribe mount.
i edited the scribe offsets in the post for the new air scribe mount,
that is all i edited in the post. now when i scribe the torch comes
down, touches off, moves to z offset, moves to the new xy offset and
scribe turns on. scribe on also lowers the air slide mount. that is
all good, but now the z axis moves up, maybe a half inch scribing a
3/8’’ hole. so i scribe air now.
anyone have an idea of what went wrong? all i modified in the post was
the scribe offsets.
Reply to sender (> <les.newell@fastmail.co.uk>> ?subject=Re%3A%20scriber%20post) . Reply to group (> <sheetcam@yahoogroups.com>> ?subject=Re%3A%20scriber%20post) . > Reply via Web Post > . > All Messages (2) > . > Top ^ >
Visit Your Group >
Unsubscribe (> <sheetcam-unsubscribe@yahoogroups.com>> ?subject=Unsubscribe) • > Terms of Use >
.,._
Posted by: K Ohlgren <kohlgren@gmail.com>
Visit Your Group
,.,_
lesmy plate marker is tool ‘‘T100 Plate marker’’ if that helps on the m09 command
On Thu, Dec 11, 2014 at 3:11 PM, K Ohlgren <kohlgren@gmail.com (kohlgren@gmail.com)> wrote:
On Thu, Dec 11, 2014 at 6:55 AM, <> sheetcam@yahoogroups.com > (> sheetcam@yahoogroups.com> )> wrote:
SheetCam Group >
1a
if(tool > 99) then
to:
the scribe offsets.
Visit Your Group >
.,._
Visit Your Group
,.,_
i should have posted this gcodethe part is a rectangle with half a circle cut into one edge
i have the scribe starting midway on the half circle, then the rectangle and finishing the half circle
i can see what it’s doing just can’t figure out how to fix it
it appears to be rising to z0.9 (my plasma rapid height) my current scriber offsets are:
scriberX = 0.00
scriberY = -85
scriberZ = -00
i have z at 00mm now so i can figure out what i need to go up or down
at the end of the gcode N0260 G00 Z0.3937 zaxis dives from .9 to .3937
this gcode has the suggested m09 fix in it that doesn’t work
N0010 (Filename: junk5.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 11/12/2014)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: 3 inch fixture)
N0080 (Operation: No Offset, 0, T100: Plate marker)
N0090 G00 X9.1573 Y5.6267
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.0520
N0130 G92 Z0.0
N0140 G00 Z0.3937
N0150 Y2.2803
N0160 Z0.3937
N0170 M08
N0180 G04 P1
N0190 G02 X6.0450 Y5.1273 Z0.9000 I0.0003 J3.1250 F50.0
N0200 G01 X4.8668
N0210 Y1.2450
N0220 X13.5148
N0230 Y5.1267
N0240 X12.2702
N0250 G02 X9.1573 Y2.2803 I-3.1126 J0.2785
N0260 G00 Z0.3937
N0270 X0.0000 Y0.0000
N0280 M05 M30
On Thu, Dec 11, 2014 at 3:13 PM, K Ohlgren <kohlgren@gmail.com (kohlgren@gmail.com)> wrote:
On Thu, Dec 11, 2014 at 3:11 PM, K Ohlgren <> kohlgren@gmail.com > (> kohlgren@gmail.com> )> wrote:
SheetCam Group >
1a
if(tool > 99) then
to:
Visit Your Group >
.,._
Visit Your Group
,.,_
I had similar problem and it was that while I am set in the XY plane, any reference to the perpendicular plane (Z-axis) within the G02/03 code is treated as a helix move. I assume you are also working in the XY-plane and I see your Z axis referenced in you posted gcode.
“N0190 G02 X6.0450 Y5.1273 Z0.9000 I0.0003 J3.1250 F50.0”
It should move the distance specified with in the G02 move.
You may want to look in the OnArc() function to see if there is a problem in there.
HTH
Paul
.,._
Posted by: urbnsr@yahoo.com
Visit Your Group
,.,_
Are you sure you are using the edited post? I just tried it here and it
worked as expected.
I’m not sure what is happening there. Could you send me the job file so
I can test using your settings.
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
