Hey there,
i just tried to delete a contour from a DXF in Sheetcam TNG, but it is not possible?
I could have sworn it WAS possible earlier? What am i doing wrong?
Thank you in advance ![]()
Hey there,
You can’t delete a contour. You can however move it to another layer. When I want to do this I just move the offending contours to a new layer that I call deleted. I then turn that layer off so I don’t see it.
Wow, that was fast ![]()
Thank you very much!
I know the moving-trick, but i was hoping for a one-hit-solution.
Would it be possible to automatize this in one of the next releases? Maybe by hitting the DEL-Key? ![]()
e.g.
Mark a contour, hit DEL and it will be moved to a Layer called DELETED, without confirmation (or with the typical DON’T ASK ME AGAIN-feature)
Anyhow, thank you very much for your fast reply
