cybermation machine
Hi i have a cybermation 700a it is used for hvac and i would like to use it for art files. I can import dxf files but the process i cumber sum. I don’t see my machine profile in the list dose this support it
You’ll probably have to choose a machine post that is close and adjust it to suit your machine. The posts are real easy to modify, which is one of the things that make SC so flexible.
Does it have a THC? Most of the HVAC plasma tables I see don’t. That would make it a little easier to make a post for the machine.
Cybermation had a software called DXF File Transfer or Autocad Utilities. With a DXF file named with equal to or less than 8 characters you can generate a QuickDraw Part. The QuickDraw part is then used in a take off.
