Cutting upside down
I just got my table up and running(bulltear) and its great but after cutting a few parts it starting cutting the parts upside down. I dont know what happened
The parts are right side up in sheetcam, its not that big of a deal except when doing number or letters because it leaves the dross on the side that should be face up.
This is a settings issue on your machine. Either your X or Y are moving in the wrong direction. Stand facing the table with the X axis parallel to your shoulders. X+ should move the cutter right. Y+ should move it away from you.
So i would stand on the right side of my table where the computer table is in the pic looking toward my plasma table and check the movement from there correct?
Yes. Assuming the left hand corner nearest to you is 0,0 then X+ would be to the right and Y+ would be away from you.
THanks, my x axis was the problem reversed it and all is good.
