Hello,
Two questions:
- is there a way to specify the start points in exact coordinates, instead of with the mouse?
- is there a way to have the start points ‘snap to grid’?
I’d find those features handy for my application. I run two post processors over the same drawing. First pass drills holes, second pass does the cutting. If I create a second operation (different tool) the default start points are not the same as the ones I set in the first operation. Trying to pick the same start points with the mouse isn’t doable. So what I do now is have just one operation, and then after I post with the first tool, I edit the operation and change the tool and use another post.
Here’s a video of the machine (I talk about SheetCAM at the 5min mark). SheetCAM made doing the inner cuts possible, the post processor tools are awesome. Before I was using a foam wire saw CAM package, but that would just create a cut path that went through the material for the inner contours. Thanks for making SheetCAM!
FWIW I’ve attached my posts in case anyone might need a similar approach.
Video
SheetCAM_DiamondWireSawPost.zip (2.48 KB)
