Hello everyone,
I bought a miniTHC torch height controller and installed it on my setup. I then took the ‘Mach3 THC with scriber’ post and modified it to remove the scriber part. I did a couple of test cuts and everything seemed to be working fine.
But now I’m trying to cut an ad and the movements seem clumsy and abrupt, i.e., instead of a soft arc, I seem to get a series of short arcs/lines. At first I thought it was a problem with my DXF file, but then I redrew a curve and although it improved, I can still see when the machine stops and then resumes.
Can someone please help me figure out the reason it is moving this way?
I made a couple of videos:
https://youtu.be/aOWeHufTph8?t=16s
https://www.youtube.com/watch?v=PczIAB4oJFg
I’m also attaching my DXF files for the first and second videos, as well as the corresponding G code for each one and the post processor I used to generate both.
Thanks a lot.
Mario
