Hello!! Happy to find a board that is Sheetcam related! Hopefully you guys can help. I’m new to all of this CNC stuff.
I have a design I created in Adobe Illustrator. I can successfully import the .dxf into Sheetcam. However, in order to “fill in” the inside lines and just cut 1/8in into my material, I need a series of inside offsets to make that happen. Right now the .dxf file is a simple outline. As an example, take a circle. I want to cut the complete interior circle, all inside offset, 1/8th inch into a 3/4in piece of ply wood. Am I making sense?
I’m hoping there is a quick command for this - instead of me having to go back into Adobe Illustrator and inside offset my whole design. That would suck
I’m using a router bit with a .25in diameter.
Thanks in advance!
