Thanks Les,
I am waiting on a set of different sizes coming next Monday. I have used all I had in stock, but didn’t have any that would fit the USB cable inside the control box. I am hoping that will sort the problem out.
I will also try using LaserGRBL instead of UGCS. I have been using LaserGRBL with my DIY laser engraver for a few years now and it is very good and I don’t see why I couldn’t use it for sending out sheetcam code to my machine.
This morning I disconnected the plasma machine from the CNC table.
I ran a small sheetcam file to test the CNC table and it all worked fine without any problems. (no plasma connected)
The plasma machine was on the opposite side of the room, so I ran the program again and while it was running I manually used the plasma cutter away from the CNC table, and the same thing happened, the CNC froze as soon as the pilot arc started. There must be a lot of EMI radiating from that plasma cutter to do that.
The plasma cutter is advertised as CNC compatible, but in no way can that be true for it to act like this.
I think I have done my money on this Chinese machine, it was not a good buy to have these problems.
These machines aren’t made well for CNC tables as you are finding out but they can be used. It takes extra care and planning when wiring the table to mitigate EMI issues. I’m currently working on my first CNC table using a Colossal Tech Cut50DF. It too is a pilot arc machine but uses HF in conjunction with the pilot arc to start cutting. I’m still working through some bugs but as of now it will cut simple parts.
My EMI issues came up as a triggered E-Stop. Reviewing forums I found that rewiring the E-Stop to trigger on pull down instead of pull up fixed my issues. I still have trouble with my laptop touch pad locking up but the table seems to run ok. Now I need to figure out how to get the torch to turn off after the cut is made.
On another note These Cut50 plasma units aren’t that bad. The torches and consumables are junk so plan on buying a bunch. As mentioned before they aren’t the easiest to get running on a CNC table but it can be done.
Yo down under - welcome to the jungle!
I´m building a DIY cnc plasma like yourself, and will use a cut50 - now you´re ahead of me since we write 2021 - what is the story?
(I might have some tips or tricks, but for sure questions for you - so - are you still here?)
Yeah, I am still here.
I haven’t used the plasma for a while, but I got it going except I was not able to have the limits working in any form whatever.
I could initiate the limits and they would work fine right up until I fired the plasma, then everything froze.
I ended up disconnecting the limits and I also had to turn off the limits in the GRBL settings as well to get the machine to work with the plasma.
I would start the machine up and set a zero point manually and then all went well.
The plasma cutter I ended up using has a low frequency pilot arc and a video of the first cuts can be seen here https://youtu.be/FAIyzK6thnI
Seems like a path similar to what I’m experiencing, did you have any success, basically my controller seems to work ok without the limit switches enabled and when I light up the torch my monitor flickers of turns off, switching from a vga cable to a dvi cable has helped a little with this but I plan on getting a longer earth clamp (5m) (already have a longer pencil torch lead 7m) and putting the unit away from everything, at first I thought it would be the torch causing the noise but my tests don’t support that theory so going to try a longer lead.
Will also be using screen cables as I used just normal single core as like you I thought I was buying a low frequency machine, the ebay seller has confirmed that it is a LF machine but I think there is a bit of poetic license being used here in the fact it might just be a lower frequency that the older versions, still HF but lower
Will also be using ferrite cores or beads everywhere I can think of.
If you found the magic bullet I’d certainly be interested in hearing more
I have been out of commission personally for a while, still learning to walk again after a medical episode and being given the wrong drug by the hospital.
Since my last post, I have changed the machine a lot. I have now installed a new system for the Z axis, one that uses a self contained lifter and THC.
I also have changed over to using Mach3 software. I have the machine running OK, but not been able to do any test cuts yet due to health issues, but all looks like it will be a better move than my previous build.
The lifter I built myself and it uses a 24 volt DC geared motor for the lifting, the controller for the lifter I bought from China which also comes with a voltage divider. The THC will work on any plasma machine and doesn’t need a Z axis as it does all the Z movement within the lifter mechanism.
The THC system used is a SF-HC25K. I got most of the information on setting it up from a youtube channel Minh’s Man Cave. The lifter I have designed and built using my CNC mill and also my 3D printer. It has a built-in floating head and up and down limit switches.
