commandcnc rotary postprocessor
When I draw a simple 2x2 inch square tube in sheetcam rotary plugin and import a simple 3 inch circle setup the job and everything everything works even the simulation but when I output the g-code there is no g-code going to the Y axis . I’m using CandCNCPlasmaLLCNCRotary_plasmaREV8a.scpost postprocessor . Does anybody know what’s going on ?
This is the job file and the g-code file
square test.txt (3.73 KB)
square test.job (24.2 KB)
