The ability to add code snippets to drilling, thread milling, and pocketing operations. I work with a 4th (A) axis on a regular basis and normally add the rotation angle in the operation “add code snippet” drop down box that way if I need to continue with that operation the next day, the rotation will always be correct regardless of the position of the 4th axis. It works fine for all other operations. I know it can be added before as a separate operation, but sometimes it is safer and more fool proof to add it to the actual operation.
