changing feed rate to inches and error on closing
Just recently upgraded pc. Running ComandCNC and sheetcam-TNG-dev 6.1.41on a plasma table
Need to change my feed rates on tools to show in/min instead of mm/min. Have done this in the past when we have replaced/repaired pc before but dont remember where I found it
I also keep getting an error on closing sheetcam, “failed to update user.configuration file”
10:36:43 AM: can’t create file ‘/home/plasma/.SheetCamTNG-dev’ (error 21: Is a directory)
10:36:43 AM: can’t commit changes to file ‘/home/plasma/.SheetCamTNG-dev’ (error 0: Success)
10:36:43 AM: Failed to update user configuration file.
The error started sometime back after trying to do an update that failed
John
log.txt (238 Bytes)
Install the latest version. That will fix the problem.
