hi all, done a very basic pattern in autocad, i have imported in into sheetcam but the text doesnt show up, i have tried exploding the parts like someone advised me too, still nothing, the part is just some contact details i want to weld to my equipment that i manufacture, nothing special,
i have attached the file if any of you would like to have a go and explan where im going wrong?
another question - is there anyone on here from wales?
thanks in advance
Chris,
Can’t explain why your having a problem.
I downloaded the drawing and opened it up to see if I could see any drastic
problems and found nothing wrong.
I then imported the drawing into Sheetcam Development 6.1.13 and the text
was there
I then tried to do a simulation of cutting and it worked fine?
By any chance, have you somehow turned the layer off in sheetcam???
Art
Country Bubba
thanks in advance
hi, thanks for the rapid response! just managed to get the text to show up in sheetcam (dont ask me how i done that!!) have run the post processor and opened it up it mach3 but only a few lines of gcode show up,
any ideas why im not getting all the gcode from this file? ive really got to get to grips with all this software soon! think im going to go nuts otherwise!!
From the looks of the gcode, it only did the “setup” part and none of the
operations.
Are you sure you made the operations before hitting post???
Best guess on my part.
Art
Country Bubba
otherwise!!
thanks les! didnt even know that existed! when i press start on the simulation a window comes up that says - warning- feedrate is zero?? where do i alter that?
I just tried your job here and it worked. I have a suspicion you may have a corrupted license. Do you have a license? Go to Help->about. Does it say if SheetCam is licensed?
