Arc Leadin/Leadout by diameter
It would be nice to have an arc lead out by diameter rather than by length of the arc.
I like to set a prestop to just as the part falls and have leadout programmed so the machine motion continues the path true to the diameter of the hole. This is not possible using the current arc leadout by length.
Possible use diameter in conjunction with angle or circumference.
