I’m very often getting annoying error messages like:
“Some paths were not generated correctly. There could be a problem with
the drawing.”
Is there a way to figure out why Sheetcam reports this? Checking the
drawing manually can be rather time consuming ant typically I don’t find
anything.
That normally indicates that something has gone wrong with the path
generation. It happens when you offset a closed contour but the end
result is an open path. This should not happen. In most cases if the cut
paths look good it will cut fine.
On 06/05/2014 19:57, Torleif Jensen wrote:
Hi.
the drawing.”
anything.
I have trouble with hidden open paths too. Sometimes it is a tiny detail in a large nest and it can be difficult to track down. Is their a way to highlight the source of the open path?
Hi.
the drawing.”
anything.
Are you getting the same warning or are tehse just ordinary open paths? You can show open paths by selecting View->show path ends. All open paths will have white dots at each end.
