I would like to create a lua script that finds all points in all parts and then add a certain shape at its location. Is this possible? I have seen the Shape plugin can add geometry so I may find out how to add geometry. But can I extract the points? There seem to be no way to list methods or properties of a part object.
local parts = sc.Parts:Get()
for i = 0, count - 1 do
local part = parts:op_index(i)
print("Part index: ",i)
print("Part operations: ", part.operations) --exists
print("Part entities: ", part.entities) --nil
print("Part objects: ", part.objects) --nil
print("Part geometry: ", part.geometry) --nil
print("Part name: ", part.name) -- exists
That’s a fairly big task. In Windows explorer go to SheetCam’s install folder (usually something like c:\program files (x86)\Sheetcam TNG. In there open the SDK folder. The .i files are the definitions for all of the SheetCam specific Lua extensions. You can open them with any text editor. For instance part.i shows all of the methods of the Parts and Part objects. The actual part geometry is stored in the ‘groups’ member of the Part object.
When creating geometry copy the method used by the shape plugin. Directly modifying groups could have unexpected consequences.
Thanks. I managed to achieve what I wanted. Not fully satisfied with the positioning of the editable object when placed into the part but it works. Here is the code:
function OnStart(event)
local count = parts:GetCount()
for i = 0, parts:GetCount() - 1 do
layers = part.layers
layername = "transformed points"
lidx = layers:NameToLayer(layername)
if lidx == -1 then
templayer = sc.Layer()
templayer.name = layername
layers:Add(templayer)
lidx = part.layers:NameToLayer(layername)
groups = part.groups
local groupcount = groups:GetCount()
pts = {}
maxx = -1e13
minx = 1e13
maxy = -1e13
miny = 1e13
partpos = part:GetPosition()
for j = 0, groupcount - 1 do
local group = part.groups:op_index(j)
if group.isCircle and group:Length() == 0.0 then
layer = part.layers:op_index(group.layer).name
ctr = group.ctr
maxx = math.max(maxx,ctr.x)
minx = math.min(minx,ctr.x)
maxy = math.max(maxy,ctr.y)
miny = math.min(miny,ctr.y)
pts[#pts + 1] = ctr
group.layer = lidx
if #pts > 0 then
tempObj = sc.EditableObject("point replacements")
tempObj:SetLayer(layer)
tempObj:InsertIntoPart()
tempObj:StartPaths()
for _, pt in ipairs(pts) do
local path = sc.Path()
path.type = sc.PATH_ARC
path.start:Set(pt.x+radius, pt.y)
path.ctr:Set(pt.x, pt.y)
path.startAngle = 0
path.angle = 3*math.pi/2
path["end"] = sc.Coord2D(pt.x,pt.y+radius)
tempObj:AddPath(path)
tempObj:EndPaths()
tpos = sc.Coord2D((maxx+minx)/2+partpos.x,(maxy+miny)/2+partpos.y)
tempObj:SetPosition2D(tpos)
tempObj:Update()
--layers:Delete(lidx)
