A Problem running G code from sheetcam in Mach 3 for pocket
Hello Les,
I’m trying to cut a pocket between two concentric circles -like between the axle and the rim of a wheel. The simulator says all is well as does the Post Processor. When the G code arrives in Mach 3 and I try to run it , it only runs to the point where the pocketing is to start and there it stops .
The line reads N0090 T2 G43 H2.
I’m a beginner at this so I need help please.
Regards,
Len
You probably have Mach set up to stop on tool changes. Pressing cycle start again will start the program running.
Hullo Les,
Pressing “cycle start” again didn’t work, so perhaps some extra lines of G code might help:-
N0030 G21(UNITS:METRIC)
N0040 G40 G90 G91.1
N0050 F1
N0060 (PART:PRONTO)
N0070 (OPERATION:SPIRAL POCKET.2.T2.MILL/ROUTER.3 MM DIA 1.5MM DEEP)
N0080 S1000(MILL/ROUTER, 3MM DIAMETER)
N0090 T2 G43 H2
N0100 G00 Z4.0000
N0110 S1000 M03
N0120 X84.9500 Y64.0000
N0130 Z0.5000
N0140 G01 Z-1.000 F100
N0150 G02 X84.9500 Y64.0000 Z-1.0000 I-29.9500 J0.0000 F200.0
N0160 G01 X87.8000 Z-1.000 F200
N0170 G02 X87.8000 Y64.0000 Z-1.0000 I-32.8000 J0.0000 F200.0
The last lines then seem to be the cutter moving round in part of a circular path.
Hope this helps.
Regards,
Len
