6.9.14 Update Says SHeetCam is running
Got a notice to SheetCam TNG Development update available. Downloaded, but says SheetCam running. CLosed sheetcam - went to downloaded file ran from there. Goes thru update but then says SHeetCam running and won’t update. Ideas?
Go to the task manager and find SheetCam.exe & click end task. Then try running the update file.
When you restart SheetCam does it say ask if you want to retry the failed update?
Try restarting Windows. Does that help?
Hello, I am getting this same problem when trying to update to TNG V7.1.35 from 6.9.15 . I rebooted windows and checked if any sheetcam task was running and it is not from what I can see. (unless it is a name that does not have sheetcam in it?) When I run sheetcam it does ask if I want to try running the failed update again. When I say yes it fails again with same error. I am running Windows 11 Pro Version 10.0.22631 Build 22631
Try downloading SheetCam directly from the downloads page on the website and installing it.
Hello, I did attempt that as well with the same result.
I also attempted to install after booting in safe mode… Same result.
Even after rebooting and immediately running the installer it fails, saying SheetCam is still running? That’s very odd. I have no explanation for it.
