Sheetcam bug or some other reason arcs won't cut cam or cut
Posted: Sun May 01, 2016 1:04 pm
by Davek0974
Wasted a lot of valuable time on this
I need to cut four arcs - open lines so no offsets or lead-ins etc.
The code tests perfect in Sheetcam simulation but when loaded into the plasma/mach3 it only cuts four very sort lines, maybe 3mm long?
I have attached the code file below but I am not upto reading I/J arcs yet.
Also the DXF file
Does this code cut long 120degree arc or short 5mm lines please??
Is there a reason I cannot CAM this job?
Posted: Sun May 01, 2016 1:25 pm
This is a post processor problem. Tom knows about this and should be able to send you a replacement with the bug fixed.
Posted: Sun May 01, 2016 3:34 pm
by Davek0974
Thanks les,
I have posted over there but its not the best place to get results in a hurry
Need to get job done by Monday evening.
I will also have to cut and paste the result as my post is heavily modified for my machine.
Posted: Sun May 01, 2016 5:49 pm
If you send me the post and the job file I'll fix it for you.
Posted: Sun May 01, 2016 5:58 pm
by Davek0974
Thanks Les,
Here is a ZIP file with the POST, DXF and tap files in it.
Hope it helps
Dave
Posted: Mon May 02, 2016 1:19 pm
OK, l lied about the post. There is something very odd going on in SheetCam. If you look at the rapid paths they don't agree with the cut paths! I'm working on trying to figure out what is going on. In the mean time try starting a new job and just load that particular drawing.
Posted: Mon May 02, 2016 1:21 pm
Just found it - the overcut is causing a problem. If you set overcut to 0 it should work.
Posted: Mon May 02, 2016 1:54 pm
by Davek0974
Thanks Les, that was the answer, no idea why but overcut turned off and job finished in time for tea
![Wink ;)](./images/smilies/icon_wink.gif)
Posted: Mon May 02, 2016 2:10 pm
I need to figure out what is going on there. Overcut shouldn't have done anything. Well, at least you got the job done.
Posted: Mon May 02, 2016 2:13 pm
by Davek0974
Seems like it was cutting only the over-cut and not the job.
Very odd.
