Wasted a lot of valuable time on this
I need to cut four arcs - open lines so no offsets or lead-ins etc.
The code tests perfect in Sheetcam simulation but when loaded into the plasma/mach3 it only cuts four very sort lines, maybe 3mm long?
I have attached the code file below but I am not upto reading I/J arcs yet.
Also the DXF file
Does this code cut long 120degree arc or short 5mm lines please??
Is there a reason I cannot CAM this job?
Sheetcam bug or some other reason arcs won't cut cam or cut
- 3mm Mild Steel Large Sheet 7.tap
- (2.13 KiB) Downloaded 130 times
- Birdbath 1 Angle Gauges 2a.dxf
- (110.1 KiB) Downloaded 180 times
Thanks Les,
Here is a ZIP file with the POST, DXF and tap files in it.
Hope it helps
Dave
Hope it helps
Dave
- Archive.zip
- (8.75 KiB) Downloaded 186 times
