Building & setting up a rotary tube cutter
Posted: Mon Apr 08, 2024 6:15 pm
I have happily been using Sheetcam for a few years now on my gantry plasma table. Now I am currently getting around to setting up a rotary tube cutter using LinuxCNC to control it. The machine will be dedicated for cutting only 2" steel square tubing. I have the Sheetcam rotary plugin setup.
Couple of questions I have..
1. Will I need a torch height control integrated with this machine? I'm thinking not, but maybe someone will tell me otherwise.
2. Will I need a probe/touchoff routine in the Sheetcam LinuxCNC rotary post?
3. I currently have the machine set up as an XXYZA...with XX running on 2 rails along the length of tube, Y as the gantry, Z as torch height, A as rotary. I have seen where other guys are running different setups but am not sure for the reason, if someone has any insights about thisI would appreciate hearing them.
Thank you!
Thank you!
