Trayectory problems
Re: Trayectory problems
I found the problem. It only happens when SheetCam is set to Italian. When I last ran the tests I used your settings but changed SheetCam back to English to make it easier for me to use. Now I know what is going on I should be able to fix it.
I just uploaded an update that should fix the problem.
Interesting how a different language could cause path issues.
It was decimal comma issue. Simulation uses a custom post processor to generate a file that uses non-standard code. That file is then simulated using a special interperter. In a part of the simulation code I forgot to take into account that some countries use a decimal comma instead of a decimal point. It is now fixed so internally it always uses a decimal point.
I bet that was hard to find.
It wasn't too bad. I've had similar issues in the past so as soon as I realized it was language dependent I had a pretty good idea where the problem was likley to be.
