Went to load the current release on my shop XP PC (not connected) and get the above at install.
Ran earlier versions just fine. Around V5 ... I think.
Where, what do I need to do to get the necessary files loaded ?
Visual C++ Runtime files not found, can't run.
Re: Visual C++ Runtime files not found, can't run.
You can download the runtimes from the SheetCam downloads page. You need vc_redist. I don't think SheetCam V7.x.x will run properly on XP. If I remember correctly the V6 series was the last that would run on XP.
Thank you Les, I'll try it.
Might have to upgrade a bit.
It's getting harder and harder to support XP and as there are so few XP users left i'm afraid I can't reall justify the work.
I understand that, I don't expect XP support and I totally agree.
I've been away a while, just now getting back in to it a bit.
It looks to be running OK so far. Have to check out all the new goodies.
Last was V4. . .
Nice work Les.
Take care, my friend.
Last was V4. . .
Nice work Les.
