I am running 6.1.57 (Linux).
I often setup plasma jobs with 50+ different parts on them.
I understand here is no way of bulk applying operations to all the parts at once. The best option appears to be to setup the required operations on the first part, then copy and paste these to the other parts using ctrl-c and ctrl-v.
Once I have a specific operation in the clipboard, are there keyboard shortcuts to navigate between the Operations and Parts windows? Or do I need to use the mouse to select each part in turn from the Parts window, then move back to the Operations window before pressing ctrl-v?
I have browsed the help and done some experimentation - so the above question may sound dumb. For which I apologise in advance.
