DXF's not importing correctly
Posted: Tue Mar 01, 2022 9:22 pm
by OldHippie62
This is the first time I had seen this one. I've been using SheetCam for 4 plus years now, and I can not explain this one.The dxf is semi circular with faceted sides, but when I bring them into SheetCam, it removes the facets and replaces them with an arc.See below images.
- Draftsight file
- draftsight image.jpg (125.06 KiB) Viewed 7813 times
Now this does not happen when I use the Torchmate software for my other machine, but it does happen if I use the Torchmate X post processor for SheetCam, and any other post in sheetCam, current running 3 different ones.any help would be awesome.
Re: DXF's not importing correctly
Posted: Tue Mar 01, 2022 9:46 pm
This is an arc fitting issue. The problem is that many cad packages break arcs into lots of line segments, or output arcs as splines, which then are converted into line segments. SheetCam is set up to try to spot these and reconstitute the original arcs. In most cases this is what you want as the parts cut more smoothly. Of course in your case, that's exactly what you don't want!
In SheetCam go to Options->application options->Drawing import and halve the arc fitting tolerance. Now reload the drawing. If it is still coming in as arcs, keep dropping the tolerance until it works correctly.
Posted: Tue Mar 01, 2022 10:20 pm
by OldHippie62
Dropped it clear down to .0001 and it still happens. Just a little background, the drawing is originally created in SolidWorks and they export it as a dxf.I then bring it into SheetCam. Now I did take the same file and was able to import into the TorchMate CADCAM software and it came in correctly.So i'll see if they are doing something differently.
Posted: Tue Mar 01, 2022 10:24 pm
I'm surprised. OK, take the minimum segments for arc fitting to something like 10.
Could you send me a copy of that drawing. I'd like to run some tests on it.
Posted: Tue Mar 01, 2022 11:36 pm
by OldHippie62
Sure
also included my post that I use.
Posted: Wed Mar 02, 2022 8:54 am
I just ran some tests and taking the minimum segments for arc fitting up to 10 does fix it. I'll try to make the next release load this drawing without needing you to tweak import settings.
Posted: Wed Mar 02, 2022 4:18 pm
by OldHippie62
Thanks Les. This is why I love this program.
