Nesting Plugin not working
- Contact:
Les! Help! I knew a button was missing when I updated the other day, but couldn't figure out what it was! My nesting plugin is gone! Do i need to reinstall the plugin or is there a bug? I think the plugin had a few bugs anyway we talked about a while back... Looks like the link on sheetcam website to the plugin dpwnload isnt working.
If it matters, i had to manually update to 7.1.21. The auto-updater didnt find the update.
Re: Nesting Plugin not working
Ah, a lot has changed recently. I'll need to update the plugin.
The new update should be up now.
- Contact:
Awesome, thank you Les!! Thanks for fixing the inch metric stuff too. The only difference i am seeing in the interfaces now is the plugin just has rotation that can be any degree, myNesting has rotation of 0,90,180,ANY and then a tilt angle that can be any value. see screenshot.
- MyNesting.PNG (5.34 KiB) Viewed 9860 times
I think Nestfab allows all angles. The plugin works with both MyNesting and Nestfab.
What does tilt do?
What does tilt do?
- Contact:
My understanding is that the angle is a preset dropdown select rotation amount of 0=no rotation, 180=2 rotations, 90=4 rotations, and ANY=any degree. And then the tilt is an additional allowed rotation to the preset amount so like Rotation=90 and tilt=15 means the part could be rotated to any quadrant +/-15degrees. I have no earthly idea why you would want to do that... maybe its less computationally expensive, idk. I always find myself using 0,90, or any and never use the tilt box. I do know if I type 60 in the plugin rotation box, it defaults to 0 or ANY in nestfab, I don't remember which right now. That's the only reason I said something.
The xml spec for MyNesting/Nestfab just has an angle attribute. It doesn't actually specify any specific angles that can be used. I'll need to look through the docs to see if I can find how 'any' should be specified.
- Contact:
Les!!! HELP!!! The nesting plugin is gone after the recent update. Does it need an update to work with the recent SheetCAM update?
Sorry about that. An update should be up by now.
- Contact:
Hey Les... looks like the nesting plugin is broke again....
- Support2.zip
- (178.38 KiB) Downloaded 80 times
I didn't think I changed enough to break the plugin. I'll upload an update in the next few minutes.
