Custom G-Code for Each Toolset
I'm sure there is a simple way to do this, but I haven't figured it out yet. For my toolset, I create two G-Code snippets for THC On and THC Off that are referenced in my Path Rules. However, when I change toolsets (45A, 105A, mild steel, aluminum, etc) and apply the Path Rules, it can't find the G-Code snippets and I have to re-enter them every time. Is there a way to store those so that every toolset can access the snippets, or so they are stored as part of the toolset or path rules?
Re: Custom G-Code for Each Toolset
the gcode snippets are saved in the toolset.
so if you create the gcode snippets in both toolsets when you flip toolsets they will be there in both
once you've created the snippets just remember to save the toolsets
I feel very dumb now... Thank you!
