"Mach 3 Tangential with 3 heads" Please Support !
Hoangthangbk51
Post by Hoangthangbk51 »
Dear All :
I have plan to make the Cutting machine using the tangential knife .
My machine use Pnewmantic to up and dow the round knife and ''Pen'' to mark on the canvas.
Im using mach3 to control the machine . The post processor is "Mach 3 Tangential with 3 heads "
When i try to import the dxf file with circle have problem with G02 on Gcode . the Knife not turn .
N0010 (Filename: Testv1.tap)
N0020 (Post processor: Mach3 tangential with 3 heads.scpost)
N0030 (Date: 22/12/2021)
N0040 G91.1 (incremental IJ mode)
N0050 G21 (Units: Metric)
N0060 G53 G40 G90
N0070 F1
N0080 M98 (init.tap)
N0090 (Part: Drawing10)
N0100 (Operation: No Offset, LAYER2, T1: Mill/router, 0.001 mm diameter, 1 mm Deep)
N0110 M6 T1 (Mill/router, 0.001 mm diameter)
N0120 G43 H1
N0130 F300000.0
N0140 G54
N0150 G00 X266.522 Y40.9683
N0160 A90.0
N0170 M07
N0180 G02 A450.0 I0.0 J111.3384 F300000.0 S1000
N0190 M05
N0200 G54
N0210 G49
N0220 M05 M09 M30
After G02 don't have the coordinate ''x" ,''Y" .
I'm at a loss now. Any help would be greatly appreciated.
Thanks!
Drawing10.dxf
(132.79 KiB) Downloaded 93 times
