I have a DXF file that when imported shows no information or layers. When I looked at the drawing file , I found that there is no information on layer 0 and 1 but the designer put the outline of the part on layer 2.
The question is, must there be information on layer 0, and why does layer 2 information not show?
remove the .txt to get the dwg file of the part. The other file is another sample with the same issue.
DXF file import not correct
Re: DXF file import not correct
The attachment didn't show up.
When you import a drawing a box pops up with some options. Do you have 'Use colours as layer names' selected? If so, turn it off.
