Disable/Enable locked or unlocked parts
Posted: Mon Jul 05, 2021 8:14 pm
by djreiswig
I'm using the stable version so maybe this is already in dev, but a menu option to enable or disable the locked or unlocked parts would be handy.
I lock the parts after I cut them, and I disable the locked parts so I can post the new parts. When I want to add some new parts to an old job I have to enable the already cut parts so I can see where to place the new parts. Then I have to turn them off again to post.
So I have to disable everything and then find and enable the unlocked parts one at a time. A menu option would be great.
Re: Disable/Enable locked or unlocked parts
Posted: Mon Jul 26, 2021 4:03 am
by djreiswig
Not sure if this post got lost, or maybe nobody else does it this way.
I checked the dev version and I don't see anything like this in there.
I did notice one quirk in the dev version.
In Part Properties, the date is in the dd/mm/yyyy format. Shouldn't this be in the Windows system format?
Posted: Mon Jul 26, 2021 12:19 pm
It should. Got to Options->application options->language. Is it set to the system default language?
Posted: Mon Jul 26, 2021 2:08 pm
by djreiswig
I think it is set to English. I'll check if there is an option for default.
Any thoughts on my other request?
Posted: Mon Jul 26, 2021 2:38 pm
Sorry, I missed your previous question. I'll add it to the next dev release.
Posted: Mon Jul 26, 2021 4:50 pm
by djreiswig
Cool.
Thanks.
Posted: Wed Jul 28, 2021 3:40 am
by djreiswig
Changed to system default language and the date is now formatted to my liking. Guess that's one difference between British English and US English.
Posted: Wed Jul 28, 2021 12:21 pm
Yes. It's generally best to stick with system default unless you really need to run SheetCam in a different language to the system default (or SheetCam doesn't have a translation for the system language).
Posted: Wed Jul 28, 2021 1:54 pm
by djreiswig
I don't recall ever changing the language. Does it default to the system default language by default?
Posted: Wed Jul 28, 2021 2:07 pm
It should normally default to system default. I'm not sure why it didn't for you.
Posted: Wed Jul 28, 2021 2:40 pm
by djreiswig
No worries. Maybe I did change it.
