GRBL post
This is the place for any plugins, posts or other useful tools you have created.
regpye
GRBL post
Post by regpye »
I am running a post that is generic GRBL, and although it is working mostly, I am getting notifications that some G01 and G03 moves are not supported.
Is there a specific post written for GRBL 1.1h ?
The post I am using is shown below.
function OnNewOperation()
post.Text (";Operation: ", operationName, "\n")
firstPierceTime = 0 --this is an extra delay added to the first pierce as needed by some machines
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("GRBL plasma post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Generic plasma post for machines with or without THC\n")
ctrl:AppendText("No comments\n")
ctrl:AppendText("M04/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
function OnInit()
if(scale == metric) then
post.Text (" G21\n") --metric mode
else
post.Text (" G20\n") --inch mode
firstPierce = firstPierceTime
function OnFinish()
post.Text (" M05 M9 M30\n")
function OnRapid()
post.ModalText (" G00")
post.Eol()
function OnMove()
post.ModalText (" G01")
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Text (" J")
post.Eol()
function OnPenDown()
if (preheat > 0.001) then
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
post.Text ("\n M04 M8\n")
if (pierceDelay + firstPierce > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay + firstPierce,"0.###")
firstPierce = 0
post.Eol()
function OnPenUp()
post.Text (" M05 M9\n")
if (endDelay > 0) then
post.Eol()
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
regpye
Re: GRBL post
Post by regpye »
I am also think about using a stand alone THC and not sure how this will effect the use of SheetCAM as the Z axis will no long be controlled by my motion software. I am still not sure about how the stand alone system works fully, but I am sure that there will need to be some changes to accommodate for the different behaviour of the machine.
Although I have been getting the messages appear about M01 and M03 not supported, the file seems to process correctly.
Re: GRBL post
Could you give me the exact warning message.
Does the THC completely control the Z? If so you can probably still use this post. Simply don't connect anything to the Z axis.
regpye
Re: GRBL post
Post by regpye »
Thanks Les,
The warning is displayed in Universal Gcode Sender. It has small warning triangles against the lines that hold G01 and G03 code and when the cursor is placed over the line in question, a message shows that the code may not be supported.
The code seems to complete without any errors.
I was think about what you mentioned about the Z axis, I had the same idea. I am not sure yet about how the stand alone system works (it hasn't arrived yet) and I have not been able to get much information from the supplier. The unit I have purchased is SF-HC25G/25K with a lifter.
Re: GRBL post
That's odd. GRBL supports both G01 and G03. Could you post a copy of your g-code here.
