Shape library for 6.1.57 version?
Posted: Sun May 23, 2021 7:07 am
by hans
Is there a possibility to use the shape library for V6.1.57?
I copied the extension folder and the icon appeared in the tool bar, but starting this results in an error message.
Any workaround or simply not usable with that version?
Re: Shape library for 6.1.57 version?
Posted: Mon May 24, 2021 12:30 pm
The current shape library relies on functions that are only available in V7.x.x.
Posted: Tue May 25, 2021 6:12 pm
by hans
Is there also an older version of the shape library that works with that version?
Posted: Wed May 26, 2021 3:15 pm
The Windows versions around that time had a version of the shape library. You could try using the files from the V6.1.x Windows versions.
Posted: Wed May 26, 2021 4:57 pm
by hans
Can you please post such a version? I have only a V5.1.7 that doesn't have this plugin. Thanks.
Posted: Thu May 27, 2021 12:22 pm
Posted: Thu May 27, 2021 8:00 pm
by hans
Thanks! The included shape library works with the 6.1.57 Linux version. Great!
Posted: Sat Jun 05, 2021 5:41 pm
by cdedwards
something else you might try, is install wine and then install the windows 7.x version of sheetcam. it work quite well
Posted: Tue Aug 03, 2021 11:43 am
by TJS
Please school me on how to get the shape tools in my CommmandCNC Linux set up. 6.1.57 32 bit version. I have posted on the commandCNC form but no response. I have my lic thru commandCNC.
Thanks.
T.J.
Posted: Mon Dec 06, 2021 8:26 pm
by hans
Just download and install the 6.1.67 Windows version and copy the shape lib folder to the linux installation. If I remember correctly, this is all.
