Post processor failed
Posted: Mon May 17, 2021 6:51 pm
by pgilley
This problem is happening for some files and not others. The message I receive from Sheetcam when this happens is:
An unexpected error has occurred :
Unable to open output file F\Julia1.tap
This error occurred on line 1197 in file ..
\Comlib\postmacro.cpp)
Post processing failed
Re: Post processor failed
Posted: Mon May 17, 2021 7:10 pm
Either drive F is not writeable or that file is locked. Try saving it to a different drive.
Posted: Mon May 17, 2021 8:26 pm
by pgilley
I have other files on same drive that work. Also cannot connect to update server. The Sheetcam version I am using is a rather old version. 6.0.30 version
Posted: Mon May 17, 2021 10:16 pm
by djreiswig
Not sure if it's your problem or not, but your file path is missing a colon after the drive. Should be F:\Julia1.tap
Posted: Mon May 17, 2021 10:29 pm
by pgilley
My fault about the colon. Missed it when typing message.
Posted: Mon May 17, 2021 10:55 pm
by djreiswig
Dang. I thought I was on to something.
Posted: Mon May 17, 2021 11:09 pm
by pgilley
Had some problem with files not post processing ever since I updated to 7.0.13 version. Liked the older versions better. Less complicated. I have an older plasma table working with Windows XP. Just hobby work.
