Rapid moves through part when cutting tabs
Posted: Tue May 11, 2021 8:51 pm
by LongRat
- image_2021-05-11_214904.png (19.51 KiB) Viewed 428 times
Ver 7.0.13, when cutting a tab which is on a curved surface, rather than an arc move to follow the part contour I am getting a couple of linear rapids which collide with the part.
Re: Rapid moves through part when cutting tabs
Posted: Wed May 12, 2021 10:46 am
It will do rapid moves if the tab thickness takes the cut above the rapid clearance height. Either raise the rapid clearance height or reduce the tab thickness.
Posted: Wed Jun 09, 2021 10:08 pm
by LongRat
Thanks for the response Les.
