Problem after upgrade to 7.0.12
I was using Ver. 7.0.11 this morning with no problems. The next time I started Sheetcam it upgraded to 7.0.12. I started a new project and imported a .svg file as usual. Selected a plasma operation and it assigned the cut sequence as usual. When I do a simulation, it only goes to the start points and does NOT follow the cut path. Did a post process to generate the GCode and looked at it. Same thing....no path....just moves the torch to the start points. Fortunately I had a backup of version 7.0.10. Restored that from my backup program and it works. Seems to be a major problem with 7.0.12???
Re: Problem after upgrade to 7.0.12
I'm also having the same problem ... I need version 7.0.11, I'm out of work ... Help sheetcam !!
Oh, that's not good I just pulled the update. You can download the previous version from https://www.sheetcam.com/downloads
Ho hum, looks like I'm not going to bed at a sensible time tonight...
OK, new update is out. Sorry about that. It's a good job you reported this when you did. An hour later and I would have been in bed...
