G Code not loading to Mach 3 Properly
I can download art and import the dxf file to sheetcam and create job files fine. When I run the post processor the tap file created is not complete. When I open the g code in Mach 3 it is only producing a few lines of code. Please help. I have attached the dxf, job and tap file for you to see. I should also note that previously downloaded and converted files open fine in Mach 3. This issue just started and I need help!
- 3Gnomes with Hearts.tap
- (208 Bytes) Downloaded 147 times
- 3Gnomes with Hearts.job
- (97.36 KiB) Downloaded 156 times
- 3Gnomes with Hearts.dxf
- (412.72 KiB) Downloaded 138 times
