Tool Table Brainstorm
Posted: Tue Apr 27, 2021 11:35 am
I need some help coming up with a better solution to my current tool table situation. We just got bit in the butt by a job because I do not have path rules set up to account for the corners and starts on our laser machine. The job on 1/2" stainless took about 2.5 times longer to cut than sheetcam predicted, not sheetcam's fault, totally my fault.
The laser control interface handles all the corner controls, start controls, pierces, everything. I just need to make sheetcam mirror this so the report times will come out right. Each and every material and thickness we cut has 8 different power/feed settings as well as a pierce, a start, and two corner settings.
I currently have my tool table set up with a separate tool for every material and thickness. 50 tools right now. It currently only programs one of the 8 available power/feed conditions, but that hasn't been a big issue. My issue is path rules... since every single material and thickness has different start and corner conditions so I would need 50 separate path rule sets as well. Which i guess would be okay if there isn't another option, but it would be awesome if the path rule set could be linked to each tool.
I wish I could do something like select a tool, path rule sets be tied to this tool, and then select a sub-tool for any one of the 8 cutting speeds or etch. This would actually be helpful to our plasma machine as well. I would imagine this tool method would mess up the mill side of sheetcam though.
Does anyone have any other thoughts?
