I get a "some toolpaths were not generated correctly - please report this as a bug" when adding tabs to open paths.
I have only experienced this with release 6.9.17
Adding tabs to open paths
- Support.zip
- (27.69 KiB) Downloaded 42 times
Re: Adding tabs to open paths
There is very little room for the ramps and it is getting stuck trying to fit the ramps in. If you run simulation on that cut you'll see what I mean.
I'll try to fix it for the next release.
