Hi Les, something seems wonky with the new start point pop-up window. When trying to switch cut direction it will change from outside offset to inside offset on a drawing with an inside cut but will not stay as reversed...Unless this is a new feature!
Thanks, Steve
6.9.16 Reverse cut direction
- 6.9.16 cut direction.PNG (171.45 KiB) Viewed 2385 times
Re: 6.9.16 Reverse cut direction
Also, I can't edit tool name/description. The curser is only there momentarily.
Thanks, Steve
Thanks, Steve
