Here's how the code should be between two cuts:
N0230 G00 Z10.0
N0240 X110.6988 Y146.8674
N0250 (---Go to pierce height---)
N0260 Z5.7000
N0270 M03 (---Torch ON---)
N0280 G04 P2000
N0290 Z4.6000 (---Go to cutting height---)
N0300 G01 F100.0
N0310 G02 X107.4988 Y143.6674 I-3.2000 J0.0000 F240.0
N0320 I0.0000 J7.2500 F435.0
N0330 X105.9903 Y145.9251 I0.3746 J1.8831 F240.0
N0340 M05 (---Torch OFF---)
N0350 G00 Z10.0
N0360 X174.0473 Y341.8340
N0370 (---Go to pierce height---)
But this is the code the postprocessor is producing:
N0230 G00
N0260 Z5.7000
N0280 G04 P2000
N0290 (---Go to cutting height---)
N0300 G01 F100.0
N0350 G00
Also, I wonder how could I get the postprocessor to include the programmed coordinated system in the code, and to always send it at rapid movement height at the start of every code. Anyinsight would be much appreciated.
I attach the postprocessor file.
