Sheetcam Settings
Roc
Sheetcam Settings
Post by Roc »
Just purchased sheetcam to use in conjunction with Inkscape. Running a fairly large Messer Plasma Table that uses OmniFab cam software. Played with the settings and it took a bit but managed to burn some test parts. Have since tinkered with the settings and have regressed. I tried deleting sheetcam without saving anything hoping that would reset sheetcam to default setting, but it did not? Upon reinstalling the settings remained the same. Would anyone be able to point me in the right direction? Cheers
djreiswig
Re: Sheetcam Settings
Post by djreiswig »
You have to delete the settings folder to reset it. Go to help..open settings folder and it will get you to the right place. It's in the user data area which is usually hidden.
Once the folder is open, I would close SheetCam before I deleted it.
Roc
Post by Roc »
On it! Thank you very much for taking the time to help me out. Greatly appreciated!
