Noob already has two questions...
Posted: Fri Aug 21, 2020 7:12 am
Hi, I'm new here, usually use either Cambam, Lazycam or Heeks, but actually evaluating Sheetcam.
I have two concerns:
One is that, although I have specified english as the default language, everything is in french. That is quite disturbing, since the french words sometimes don't make any sense, and finding a translation is tough.
The second issue is that I have imported a dxf file and I get a message saying "Aucun trou répertorié. Vérifiez les tailles mini et maxi du trou" (No holes listed. Check min and max hole size)
I'm using Heeks most of the times, which is very similar (in a simpler way), so I believe I could easily switch to Sheetcam.
I have attached said file.
