As per title, is there a way to scale piercedelay variable within the post processor?
Automatically that is, other than *.1000?
I've set the units to mSec, but the pp is still outputing in seconds
(normal fix is just to add the *1000, buy I did wonder if there was as a (time) units scale factor that could automatically be used.
Thanks as always
piercedelay scaling? (Sec / mSec in PP)
Re: piercedelay scaling? (Sec / mSec in PP)
For that you will need to change the post. The post ignores your unit settings in application options. For instance you may have a machine that only operates in metric while you prefer to design in inches.
thanks Les, thought I'd missed a units variable somewhere
